AFM Trick (20v silvertop)
Παλιά 28-06-04, 18:28
Το avatar του χρήστη kosttrd
kosttrd Offline:
Ηλικία: 47 male
Δύναμη Σεβασμού: 301
kosttrd είναι σε έναν διακεκριμένο δρόμο
Mια απλη αλλα ουσιαστικη λυση για το AFM
The AFM Trick
If you've checked out good sites on the 4A-GE, you've prob'ly noticed something about tweaking the air flow meter (AFM). So, the question is, why would you want to do that? It'll trick the ECU into thinking that there's more air going into the engine. Throttle response will increase.
NOTE: Don't expect to get big gains if you're running a stock motor. This works best with a freer-flowing engine with intake and exhaust mods and cams.
So, how do you do it?
Find the AFM. On the AE92 GT-S, it's that module on top of the air filter with a black plastic cover.
Use a sharp razor blade and cut the clear seal along the perimeter of the black plastic cover. Use a small screwdriver and pry up the cover. Make sure you don't inadvertently poke things inside of the expen$ive AFM!
You'll see a toothed wheel with a coiled tensioner spring riveted to it. This is what forces the flapper door closed. If we decrease the tension, the flapper door will swing open more for the same amount of air passing through. Neato, huh?
Wait! Before you make any adjustments, mark the clamp on the gear wheel so you have a stock reference point. If you ever need to return the AFM to the stock position, you'll need it.
Now, loosen the gear wheel clamp a little bit. Turn the gear wheel 2-5 teeth counterclockwise. Some people say 3-5 teeth, so use your own preference. I'm running it 1 tooth looser--any more and the motor loses responsiveness and power for some reason. Don't go more than 5 teeth cuz you'll just cause the engine to bog between shifts. Tighten down the gear wheel clamp.
Get some black or clear silicon caulking compound. Replace the black plastic cover, then seal it. Whatever you do, don't get white caulk--it'll attract too much attention. I used The Right Stuff because it was black--it must've worked because it didn't attract my SMOG inspector's attention. Try to do a clean and thorough job--you DO NOT want crap or moisture getting into the AFM assembly.
Όνομα:  ae92gts_afm.jpg
Εμφανίσεις:  41
Μέγεθος:  48,2 KB
Japanese Power http://www.corollaclub.com/forums/cu...atar4562_1.gif
Παλιά 29-06-04, 10:30
Το avatar του χρήστη UNIQUE
UNIQUE Offline:
Μοντέλο: ΕΕ111
Δύναμη Σεβασμού: 317
UNIQUE είναι σε έναν διακεκριμένο δρόμο
Το έχω γράψει στο EFI - AFM TIPS.
Πάντως απο ότι έχω διαβάσει σε forum του εξωτερικού το "πράγμα" δουλέυει.
MY SITE
Re: AFM Trick (20v silvertop)
Παλιά 29-06-04, 13:36
Anonymous Offline:
Αρχική Δημοσίευση από UNIQUE";p="5606
Το θεμα ειναι για ποσο?
Παλιά 29-06-04, 19:01
kosttrd Offline:
Ηλικία: 47 male
Αρχική Δημοσίευση από xenos";p="5615
Μαλλον θα το κανω την Παρασκευη και θα σαν αναφερω εντυπωσεις....
Παλιά 29-06-04, 19:21
kosttrd Offline:
Ηλικία: 47 male
Για να ειμαι ειλικρινης δεν ειχα ψαξει στο forum,για κατι τετοιο.Ρωτησα τον μηχανικο μου και μαλλον κατι θα κανουμε....Μου ανεφερε ομως οτι ισως λογω της μεγαλης ευαισθησιας που θα εχει το ελατηριο (μιας και θα ανοιγει πιο ευκολα και με μικροτερη πιεση αερα),ισως να εχω προβλημα με τα καυσαερια στο ρελαντι.Παντως θα το δοκιιμασουμε.Για να δουμε τι θα καταφερουμε....
Παλιά 11-07-04, 12:47
Το avatar του χρήστη Χρηστος
Χρηστος Offline:
Μοντέλο: carina e 20v st
Δύναμη Σεβασμού: 396
Φιλε kosttrd τι εγινε τελικα με το AFM?του πειραξες τα δοντακια?αξιζει ο κοπος?
Παλιά 11-07-04, 12:56
kosttrd Offline:
Ηλικία: 47 male
Αρχική Δημοσίευση από Χρηστος";p="5996
Δυστυχως,δεν προλαβαμε να το κανουμε με τον μηχανικο μου.Θα το κανουμε ομως σιγουρα και με την πρωτη ευκαιρια θα σου αναφερω εντυπωσεις...
Παλιά 01-11-04, 16:39
spider Offline:
Δύναμη Σεβασμού: 262
spider είναι σε έναν διακεκριμένο δρόμο
Γνώμη μου:
ΜΗΝ ΤΟ ΑΓΓΙΞΕΙΣ
ΧΑΛΑΕΙ...
This post will self-destruct in five seconds, take your f*****ng car and run.........
εξατμιση σε 20v silvertop vasilis ae92 4AGE 20v Levin 3 07-05-17 17:38
Trick για Ηλεκτρικά Παράθυρα! Timekiller TOYOTA COROLLA T-SPORT 15 18-02-11 16:16
20V silvertop vs 20Vblack top MARMEL ΔΙΑΞΙΦΙΣΜΟΙ 90 29-05-10 17:02
silvertop H blacktop. nikos carina 4AGE 20v Levin 31 14-08-09 17:03
4age 20v Silvertop Σε G6 makis7 TOYOTA COROLLA 111(G6) 3 23-01-05 01:41
Page generated in 0,15412903 seconds (80,37% PHP - 19,63% MySQL) with 38 queries
Όλες οι ώρες είναι GMT +3. Η ώρα τώρα είναι 04:10.
