3ZZ 1.6L VVTi Tεχνικα χαρακτηριστικα και αναβαθμισεις .2000 με 2007. |
TOYOTA 3ZZ - FE Engine |
02-11-11, 20:07
Εύβοια
The 3ZZ-FE is a 1.6 L ( 1598 cc ) incarnation built in Japan. It is found in the Asian Toyota Corolla Altis which is available in countries such as Singapore, Malaysia, Philippines, Thailand and Taiwan and in the Toyota Corolla sedan sold in Sri Lanka. In South Africa the motor can be found in the RunX 160 and Corolla 160. The entire exterior design and chassis is the same as the American Corolla. Bore is 79.0 mm and the stroke is 81.5 mm. Max. output is 109 hp (81 kW) @ 6000 rpm Max. torque is 110 lb/ft. of torque (150 Nm) @ 3800 rpm
Τελευταία επεξεργασία από το χρήστη corolla 1.6 VVT-i : 03-11-11 στις 02:19.
Page generated in 0,14024496 seconds (72,90% PHP - 27,10% MySQL) with 24 queries
Όλες οι ώρες είναι GMT +3. Η ώρα τώρα είναι 08:11. Συνολικές Εμφανίσεις: |
