TOYOTA COROLLA T-SPORT 2002>
ZZE Part Numbers
Παλιά 09-05-07, 12:22
hatzidi2 Offline:
Μοντέλο: COROLLA TS 2003
ZZE Part Numbers
part numbers τα οποία βρήκα σε αυτό το λινκ http://au.toyotaownersclub.com/forum...howtopic=10160
και απλα τα κανω copy paste γιατι τα βρισκω χρήσιμα.
Brakes
Rotor
RDA Front:
RDA Rear:
DBA Front: DBA759(S)(XS) http://www.dba.com.au/2006/default.asp αντιπροσωπος www.nt.gr/gr
DBA Rear: DBA713(S)(XS) http://www.dba.com.au/2006/default.asp αντιπροσωπος www.nt.gr/gr
Black Diamond Front: KBD1209
Black Diamond Rear: KBD1287
C-One Front: FR4351-ZE123
C-One Rear: FR4243-ZE123
Pad
Race Brakes Australia RB74 Front: DB1431 (2zz)
Race Brakes Australia RB74 Rear: DB1429
Ferodo Front: FDB1573 (προμηθευτης eltrekka, Κων/λεως 7 Περιστέρι, τιμη 49,98ευρω + 19% ΦΠΑ/09-05-2007)
Ferodo Rear: FDB1574 (προμηθευτης eltrekka, Κων/λεως 7 Περιστέρι, τιμη 39,90 ευρω + 19% ΦΠΑ/09-05-2007)
Ferodo DS2500: FCP1528H
Bendix Advance Front: DB1714 (SA build)
Bendix Advance Rear: DB1429
Bendix Heavy Duty Front: DB1422 (Japanese build)
Bendix Heavy Duty Rear: DB1429
Bendix General Front: DB1422 (Japanese Build)
Bendix General Rear: DB1429
EBC Greenstuff Front: DP21325
EBC Greenstuff Rear: DP21326
Black Diamond Front: PP544
Black Diamond Rear: PP545
TRD Red Front: 04491-ZE200 (2zz), 04491-ZW300 (1zz)
TRD Red Rear: 04492-NP100
TRD Black Front: 04491-ZT300 (2zz), 04491-ZT310 (1zz)
TRD Black Rear: 04492-ZT300
C-One Type SS Front (2zz): CP0491-ZT231
C-One Type SS Rear (2zz): CP0492-ZT231
C-One Type R Front (2zz): CP0491-ZT23R
C-One Type R Rear (2zz): CP0492-ZT23R
Other
TRD Braided Brake Line: 47031-ZE200
C-One Braided Brake Line: CH4700-ZE123
Mintex Caliper Front: MBA1319A
Suspension
Coilover
D2 Street:
D2 Track:
Cusco Zero 1: 166 60E CN (F0 to -55mm & 7kg/mm, R-10 to -75mm & 5kg/mm)
Cusco Zero 2: 166 60L CN (F0 to -55mm & 7kg/mm, R-10 to -75mm & 5kg/mm)
Tein Super Wagon: DSY60-91SS3 (F-40 to -60mm & 3kg/mm, R-50 to -70mm & 3kg/mm)
Tein Basic Wagon: GSY60-J1SS2 (F-40 to -60mm & 3kg/mm, R-45 to -65mm & 3kg/mm)
Tein EDFC Controller: EDK04-K4469
Tein EDFC Motor: EDK05-12120
TRD Sportivo (1zz): (strut) 48030-ZE210, (spring) 48130-ZE210
TRD Sportivo (2zz): (strut) 48030-ZE230, (spring) 48130-ZE230
TRD Sportivo WayDo (1zz): (strut) 48030-ZE200, (spring) 48130-ZE200
TRD Sportivo WayDo (2zz): (strut) 48030-ZE220, (spring) 48130-ZE220
C-One SS Front: CS4800-ZE124
C-One SS Rear: CS4800-ZE123
C-One Sports (2zz): CS4801-ZE123
C-One Sports (1zz): CS4801-ZE124
Spring
King Springs Low Front: KTFL-105
King Springs Low Rear: KTRL-106
King Springs Standard Rear: KTRS-106
Tein S-Tech (1zz): SKY90-S1B00 (F-45mm & 3.4kg/mm, R-40mm & 3.0kg/mm)
Tein S-Tech (2zz): SKL56-S1B00 (F-50mm & 3.9kg/mm, R-45mm & 4.2kg/mm)
Tein S-Tech (2zz): SKY60-S1B00 (F-50mm & 1.9-2.6kg/mm, R-35mm & 1.5-3.4kg/mm)
Tein High Tech (2zz): SKY60-G1B00 (F-40mm & 2.3kg/mm, R-30mm & 2.1-2.9kg/mm)
Tein High Tech (2zz): SKL56-G1B00 (F-40mm & 3.5kg/mm, R-35mm & 2.9kg/mm)
C-One (1zz): CS4810-NE120 (F-35mm & 3.1kg/mm, R-30mm & 3.6kg/mm)
C-One (2zz): CS4810-ZE121 (F-35mm & 3.1kg/mm, R-30mm & 3.6kg/mm)
Apexi SLD: 236-T075 (F-55mm & 2.6kg/mm, R-45mm & 2.9kg/mm)
Whiteline Control Front: 73205 (-25 to -40mm)
Whiteline Control Rear: 73206 (-25 to -40mm)
Whiteline Control Rear (wagon): 73247 (-25 to -40mm)
Eibach Pro Kit:
Strut
Koni Front: 8610-1416Sport
Koni Rear: 80-2844Sport
KYB GR-2 Front: 334450
KYB GR-2 Rear: 341816
Monroe GT Gas Front: E7008+
Monroe GT Gas Rear: E1312+
Strut Bar
TRD Front: 53607-ZE200
TRD Rear: 53605-ZE200
C-One Sports Front: FT5360-ZE123
C-One Sports Rear: FT5361-ZE123
C-One Type R Front: FT5360-ZE12R
C-One Type R Rear: FT5361-ZE12R
Cusco Front: 193 540 A
Whiteline Front: KSB603
Anti-roll Bar
TRD Rear: 48812-ZE200 (23mm)
C-One Front: CS4881-ZE123 (24mm)
C-One Rear: CS4883-ZE123 (23mm)
Cusco Rear: 902 311 B23 (23mm)
Whiteline Front (1zz): BTF72(Z) (24mm)
Whiteline Front (2zz): BTF85(Z) (24mm)
Whiteline Rear: BTR77 (22mm)
Other
TRD Suspension Member Brace Rear: 51503-ZE200
C-One Suspension Member Brace Front (2zz): FB5140-ZE123
C-One Suspension Member Brace Rear (2zz): FB5229-ZE123
TRD Mechanical LSD (2zz): 41301-ST804
Kaaz LSD (2zz): DBT2100 (1.5-way)
Cusco Type RS LSD (2zz): LSD 186 C (1-way), LSD 186 C15 (1.5-way)
C-One Engine Damper (2zz): CE1240-ZE123
C-One Upper Pillow Mount Front: CS4860-ZT230
TRD Strut Top Mount Plate Front: 48688-ZE200
Whiteline Camber Adj. Bolt Front: KCA415 (+/-1.5*)
C-One Suspension Bush Upper Rear: CS4875-ZT231
εαν παλι καποιος βρει λαθη ας το αναφέρει να τα διορθώνουμε ή ακόμα και οποια εχουμε ήδη δοκιμάσει να λεμε εντυπώσεις, τιμη και προμηθευτη ωστε να ξερουμε που ψαχνουμε χωρις κόπο
Τελευταία επεξεργασία από το χρήστη hatzidi2 : 10-05-07 στις 00:08.
Παλιά 09-05-07, 18:14
PeterIoannou Offline:
Μοντέλο: Avensis ZZT223
Ηλικία: 56 male
Δύναμη Σεβασμού: 422
Μπράβο φίλε μου, πολύ καλή δουλειά.
Να προσθέσω μόνο τα ακόλουθα:
1. Αντιπρόσωπος της ΤΕΙΝ στην Ελλάδα είναι -αν δεν κάνω λάθος- ο Ν. Τζούρδας και πιο συγκεκριμένα: http://www.nt.gr/gr και τα στοιχεία επικοινωνίας που βρήκα εκεί, είναι:
ΚΕΝΤΡΙΚΗ ΔΙΑΘΕΣΗ
ΔΑ11, ΟΤ40, ΒΙΠΕ ΣΙΝΔΟΥ,
57022 Θεσσαλονίκη
ΤΗΛ. 2310 723500 (10 γραμμές)
FAX 2310 723509
e-mail :info@nt.gr
ΚΑΤΑΣΤΗΜΑ ΑΘΗΝΑΣ
Παλαμηδίου 29, Κολωνός,
10441 Αθήνα
ΤΗΛ. 210 5156650 (10 γραμμές)
FAX 210 5156669
ΚΑΤΑΣΤΗΜΑ ΘΕΣΣΑΛΟΝΙΚΗΣ
Κερδυλλίων 3-5, Άγιοι Πάντες,
54627 Θεσσαλονίκη
ΤΗΛ. 2310 512774 & 517401
FAX 2310 532769
2. Έχω την εντύπωση (με βάση και αυτά που μου έχει πει και ο αμορτισεράς μου με τον οποίο κοιτάμε την Super Street) πως το πολύ καλό και χρήσιμο EDFC με τα παρελκόμενά του, δεν υπάρχει για την TS.
Κλείνοντας, από μια ματιά που έριξα στο site αυτό, είδα πως ο ίδιος φέρνει και είδη της C-One, της Cusco, της Endless, της Exedy, της TODA κλπ.
Οπότε, ίσως θα μπορούσες να προσθέσεις και αυτά στην πολύ καλή και μακριά λίστα που έχεις φτιάξει!
Και πάλι μπράβο σου.
Πάνος.
Fast cars do not kill.
Slow drivers, do!!!
Saneatsu Abukara
Παλιά 09-05-07, 19:35
billlllll Offline:
Δύναμη Σεβασμού: 470
Yep to EDFC δεν μπαίνει στην Ε12 (βασικά δε χωράει για να μπει)
Παλιά 10-05-07, 00:10
hatzidi2 Offline:
TEIN Shops in Greece
AUTO ERGONOMICS Athanasiou Diakou 22 Street, Moshato-Pireas, Greece +30 210 9427417 +30 210 9425371 http://www.autoergonomics.gr/
LOUIS AUTOTUNING 106 Dimokratias AV., 151 26 Maroussi, Athens, Greece +30 210 805 5612 +30 210 805 5612 http://www.louis.com.gr/
NESTOR TZOURDAS S.A. 29, Palamidiou street & Astrous street, Kolonos, 104 41 Athens, Greece +30 210 515 6650 +30 210 515 6669 www.nt.gr/gr
KYB AGX Part Number DareDevil TOYOTA COROLLA E 12 3 17-10-12 03:18
part numbers για agx και koni κιτρινα? kostas_8 TOYOTA COROLLA 111(G6) 46 27-01-12 00:10
Ταμπλώ / Part numbers mspant TOYOTA COROLLA 111(G6) 5 21-11-09 07:08
GT Live – Part Four - Nismo Day CorollaG6 PHOTOS 13 21-12-04 13:06
Page generated in 0,21355009 seconds (81,80% PHP - 18,20% MySQL) with 29 queries
Όλες οι ώρες είναι GMT +3. Η ώρα τώρα είναι 16:28.
