Trd Engines...? |
14-06-04, 11:21
Trd Engines...?
 Υπαρχουν της trd engine.Εχω ακουσει για ενα 2.0L Turbo 280ps,Ξερει κανεις.Καποιο Site.
Στου κουφού την πόρτα... πίσω έχει η αχλάδα την ουρά !!!!!
Είναι πολλά τα λεφταααααα !!!!!!
Re: Trd Engines...? |
14-06-04, 17:56
Re: Trd Engines...?
15-06-04, 12:30
sostosssssssss
15-06-04, 18:39
ΠΕΤΡΟΥΠΟΛΗ
Re: Trd Engines...?
16-06-04, 10:09
δεν εχω ιδεα τι να πω
16-06-04, 10:12
PIRAEUS
Re: Trd Engines...?
Αρχική Δημοσίευση από kosttrd";p="
ΑΠ ΟΤΙ ΞΕΡΩ Η CARLOS SAINZ ΕΒΓΑΖΕ ΠΕΡΙΠΟΥ ΣΤΑ 220 ΚΑΙ ΔΕΝ ΗΤΑΝ V6
COROLLA T-SPORT
16-06-04, 10:58
ΠΕΤΡΟΥΠΟΛΗ
Re: Trd Engines...?
Η CARLOS SAINZ HTAN 240 ΑΛΟΓΑ ΣΤΗΝ ΕΥΡΩΠΗ ΚΑΙ 260 ΣΤΗΝ ΑΜΕΡΙΚΗ. ΟΙ ΠΙΝΑΚΕΣ ΕΙΝΑΙ ΑΠΟ ΤΟΥΟΤΑ ΑΜΕΡΙΚΗΣ
3S-GTE Engine Stats
(Specs are from the US-Spec engine except where mentioned. California or non-North American Models may have slightly different specs)
Engine 2.0L four EFI DOHC
Horsepower 1994-99 260ps@6500RPM
1990-93 200HP@6000RPM
1988-89 190HP@6000RPM
Torque 1994-99 31.0nm@4000RPM
1990-93 200@3200RPM
1988-89 190@3200RPM
Bore 86mm
Stroke 86mm
Compression ratio 8.5:1 (all but 90-93 which were 8.8:1)
Models with this engine: ST205 (Generation 6 Celica GT-Four),
ST185 (Generation 5 Celica GT-Four/AllTrac)
ST165 (Generation 4 Celica GT-Four/AllTrac)
SW20 (1990-98 Turbo MR-2)
the differences of the 200hp 3S-GTE's versus
newer 240-250hp ones. This information is about the ones installed in Celica GT-4's but the same should be true for MR2's too.
1) Compression ratio was lowered from 8.8 to 8.5
2) intercooler was improved, allowing higher boost
3) intake valve lift increased from 8.2 to 8.7mm
4) T-VIS was discarded, and intake chamber enlarged from 1.16l to 1.46l
5) turbo was modified: shaft was made thinner and turbine wheel made
smaller. Flow capacity was increased from 26.4 to 37 lbs/min.
16-06-04, 11:18
ΠΕΤΡΟΥΠΟΛΗ
Re: Trd Engines...?
ΕΠΟΜΕΝΩΣ ΓΙΑ ΑΥΤΟ ΤΟ ΜΟΤΕΡ ΤΑ 280 ΑΛΟΓΑ ΕΙΝΑΙ ΣΧΕΤΙΚΑ ΕΥΚΟΛΗ ΤΙΜΗ ΜΕ ΜΙΑ ΜΙΚΡΗ ΠΑΡΕΜΒΑΣΗ ΤΗΣ TRD, ΑΥΤΟ ΤΟ ΜΟΤΕΡ ΙΔΙΩΣ ΣΤΗΝ ΤΕΛΕΥΤΑΙΑ ΤΟΥ ΕΚΔΟΣΗ ΜΕ ΤΑ 240+ ΑΛΟΓΑ ΕΧΕΙ ΦΤΑΣΕΙ ΜΕΧΡΙ ΚΑΙ 600 ΑΛΟΓΑ ΣΕ DRAGSTER ΣΤΗΝ ΑΓΓΛΙΑ
16-06-04, 11:31
ΚΑΛΛΙΘΕΑ
Re: Trd Engines...?
Αυτό το μοτεράκι φοράει ο Μπαρμπαρής στην CELICA και είναι πάνω απο 550 ΗΡ.Επίσης και η προηγούμενη CELICA του Μπαρμπαρή η άσπρη που τώρα την έχει φιλαράκι μου έχει αυτό το μοτέρ και είναι 500 ΗΡ!!!!!
Και μην ξεχάσουμε και τον πρόεδρο που φοράει το συγκεκριμένο μοτεράκι!!!
 Γειά σου πρόεδρε
16-06-04, 11:54
ΠΕΤΡΟΥΠΟΛΗ
Re: Trd Engines...?
ΣΩΣΤΟΣ UNIQUE!!!!! KAPOY DIABASA ΣΕ ΕΝΑ SITE ΓΙΑ ΕΝΑ ΤΕΤΟΙΟ ΜΟΤΕΡ ΠΟΥ ΘΑ ΞΕΠΕΡΝΑ ΤΑ 700!!!! ΑΛΟΓΑ ΑΛΛΑ ΔΥΣΤΥΧΩΣ ΤΟ ΕΧΑΣΑ ΘΑ ΤΟ ΞΑΝΑΚΟΙΤΑΞΩ
Page generated in 0,21936893 seconds (81,41% PHP - 18,59% MySQL) with 42 queries
Όλες οι ώρες είναι GMT +3. Η ώρα τώρα είναι 01:12. Συνολικές Εμφανίσεις: |
