Επιστροφή   CorollaClub Forums > COROLLA CLUB > PHOTOS
PHOTOS ΔΙΑΦΟΡΕΣ ΦΩΤΟΓΡΑΦΙΕΣ ΤΩΝ ΜΕΛΩΝ ΜΑΣ ΚΑΙ ΜΟΝΟ ΟΣΕΣ ΦΩΤΟ ΕΧΕΤΕ ΑΠΟ ΟΤΙΔΗΠΟΤΕ ΣΧΕΤΙΚΟ ΜΕ COROLLA ΝΑ ΤΟΠΟΘΕΤΕΙΤΕ ΣΤΟ PORTAL
nea Corolla ae86????
Παλιά 26-01-04, 03:24
Το avatar του χρήστη Doctor Mousas
Doctor Mousas Offline:
Doctor Mousas είναι σε έναν διακεκριμένο δρόμο
Mechanical/Performance
Engine Double overhead cam (DOHC)16-valve VVT-i 4-cylinder
Displacement 2.4 Liters
Bore x stroke
Compression ratio
Valvetrain Double overhead cam (DOHC) 16-valve with Variable Valve Timing with intelligence (VVT-I)
Induction system Multi-port EFI
Ignition system Electronic with Direct Ignition (TDI)
Horsepower 159
Torque 162
Transmission
5-speed manual overdrive Standard
4-speed electronically controlled transmission (ECT) Available
Brakes Power-assisted ventilated front/rear disc with Anti-Lock Brake System (ABS)
Exterior Dimensions (inches)
Overall height 55.7
Overall width 69.1
Overall length 173.2
Wheelbase 106.3
Interior Dimensions Front/Rear (inches)
Seating Capacity 5
Comfort and Convenience Features
Air Conditioner
Power Windows (with one-touch up/down on driver & passenger window w/ pinch protection)
Power Door Locks with Remote Entry
Power Outside Mirrors
Panorama Moonroof with Power Slide/Tilt Front Glass Panel and Dual Manual Sunshades
Rear Window Defogger
Digital Clock
Dual Power Points
Outside Temperature Gauge
Tilt-Steering Wheel
Tachometer and Trip Meter
Sport Front Bucket Seats with Fabric Upholstery and Driver's Seat Adjustable Thigh Support
Cruise Control
Cargo Area Storage
Driver's Seat One-Touch Walk-In w/ Track and Seat Angle Memory
60/40 Split Folding Rear Seat
Rear Window Shading
Driver and Passenger Sun Visor Mirror w/ Cover
Hard Cargo Cover
Amber Instrument Panel Illumination
Exterior Features
17" Alloy Wheels
Multi-Reflector Auto-off Halogen Headlamps
Side Mirrors with Turn Indicators
Intermittent Front Wipers
Chrome Exhaust Tip
Audio
Pioneer AM/FM/CD Head Unit (MP3 and Satellite controller capable XM Radio)
Scion Sound Processing
Six Speakers (including 2 tweeters)
Rear Fender-Mount Antenna
Safety Features
Driver and Passenger Front Airbags*
Driver Knee Airbag*
Anti-Lock Brakes (ABS)
Driver and Passenger 3-Point Seat Belts
Anti-Lock 4-Wheel Disc Brakes
Three-Across Rear Head Restraints
Three-Across 3-Point Rear Seat Belts
First Aid Kit
*Driver and Front Passenger Airbags –
The Scion driver and front passenger airbags are Supplemental Restraint Systems (SRS). The driver and front passenger airbags are designed to deploy in severe (usually frontal) collisions where the magnitude and duration of the forward deceleration of the vehicle exceeds the design threshold level. In all other accidents, the airbags will not inflate. To decrease the risk of injury from a deploying airbag, always wear seatbelts and sit upright in the middle of the seat as far back as possible from the airbag modules. Do not put modules in front of an airbag. Do not use rearward-facing child seats in any front passenger seat. The force of a deploying airbag SRS may cause serious injury or death. Please see your Owner’s Manual for further instructions.
note: the pics show a navigation system so that will probably be an option.
Όνομα:  sciontc3.jpg
Εμφανίσεις:  65
Μέγεθος:  67,1 KB   Πατήστε στην εικόνα για να τη δείτε σε μεγένθυνση
Όνομα:  sciontc2.jpg
Εμφανίσεις:  62
Μέγεθος:  95,3 KB
toyota corolla AE86 GTS twin cam 16v
Πισωκουνα και ξερο ψωμι!!!!!
Παλιά 26-01-04, 03:29
akoma se peiramatiko stadio!!!! eidomen......
Όνομα:  sciontc6.jpg
Εμφανίσεις:  48
Μέγεθος:  58,6 KB   Πατήστε στην εικόνα για να τη δείτε σε μεγένθυνση
Όνομα:  sciontc5.jpg
Εμφανίσεις:  43
Μέγεθος:  74,3 KB   Πατήστε στην εικόνα για να τη δείτε σε μεγένθυνση
Όνομα:  sciontc4.jpg
Εμφανίσεις:  33
Μέγεθος:  65,9 KB
Παλιά 31-01-04, 13:21
billlllll Offline:
Δύναμη Σεβασμού: 470
Πολύ ωραίο σουλούπι έχει! στα τεχνικά χαρακτηριστικά γράφει
μήπως είναι λάθος...? 2.4 λίτρα vvti και να βγάζει 159 άλογα σα λίγα δεν είναι ?
Η ιστορία του AE86 μου! FanIsHere TOYOTA COROLLA AE86 5 12-05-16 00:37
AE86 legendery car B4tiSp0t Videos 1 14-04-09 19:50
Ae86 Projects... alimonos TOYOTA COROLLA AE86 14 08-12-05 23:47
Ενισχυση πλαισιου στα πισωκινητα Corolla AE86, KE30,KE55,KE3 SavvasKE35 SUPPORT 4 02-12-05 15:44
Corolla AE86 1.6 16v PaRhS ΓΕΝΙΚΑ ΘΕΜΑΤΑ 1 05-05-04 20:13
Page generated in 0,20523190 seconds (77,24% PHP - 22,76% MySQL) with 28 queries
Όλες οι ώρες είναι GMT +3. Η ώρα τώρα είναι 02:05.
