STOP Donating Money To The GAS COMPANIES With These MIND-BLOWING TIPS
Παλιά 21-12-16, 22:52
Cool STOP Donating Money To The GAS COMPANIES With These MIND-BLOWING TIPS
1. The tip number one is related to the return mechanism that the majority of us didn`t know it exists in the petrol-kiosk pump. And here how it works – whenever there is an excess of oil, the return pipe mechanism returns back that amount to the underground tank, although you have paid for it! Lesson – do not fuel your car`s tank to the brim.
2. From now on, you should start refueling your vehicle in the mornings. Why? Temperature has one of the greatest impacts on the fuel and higher temperatures mean less fuel for you. With each degree higher temperature the petrol expands more and more, which means you will pay for a liter, but you will not receive one!
3. Do not select the fast mode when you are refueling on your own! The is to lower the amount of vapours and stop converting some of the fuel into this irrelevant substance that can occur thanks to the vapour-return system these smart pumps have.
4. Refuel your tank only when it is half full, so you can minimize the amount of fuel that evaporates! Reason? The empty space in your tank is filled with some air which causes evaporation. So, more fuel means less air and less evaporation, although some tanks have floating roofs to prevent this problem.
5. Whenever there is a petrol truck at the gas station that is pumping gas into the underground reservoirs, move on and stop at another one! By refueling your car during that time, you might get some dirt with your petrol in your tank that will cause you additional problems.
Found this article interesting? Don’t forget to share it with your friends. At last, feel free to leave your comments in the section below where you can also share some of your tips for saving gas money!
Read more: http://www.musclecarszone.com/stop-d...#ixzz4TVWqdpZH
Παλιά 24-12-16, 21:59
endurasKE-30 Offline:
Δύναμη Σεβασμού: 920
Σωστό!!!!!!!
Παλιά 27-12-16, 22:59
christojr1 Offline:
Δύναμη Σεβασμού: 212
christojr1 θα γίνει πολύ σύντομα πασύγνωστος
Πολύ ωραίο άρθρο!!!!
Stop πίσω πόρτας corolla e12 2003 diaponezos Αξεσουάρ και Ανταλλακτικά 0 20-03-21 17:50
STOP στην πώληση της Ελαφονήσου LISSAS OFF TOPIC 0 22-05-14 11:14
Καθολικό «stop» στο κάπνισμα! centaurus OFF TOPIC 11 05-06-10 16:48
Πρόβλημα με start and stop στο Auris 1.33 black21 TOYOTA AURIS 8 12-07-09 20:01
Williams lands airline money SiCorolla94 FORMULA 1 RSS Feeds 0 06-04-07 03:51
Page generated in 0,11588001 seconds (75,91% PHP - 24,09% MySQL) with 27 queries
Όλες οι ώρες είναι GMT +3. Η ώρα τώρα είναι 23:13.
