Colored Potholes!!
Παλιά 08-03-10, 20:34
Το avatar του χρήστη AE101
AE101 Offline:
Δύναμη Σεβασμού: 274
AE101 είναι υπέροχος AE101 είναι υπέροχος AE101 είναι υπέροχος AE101 είναι υπέροχος AE101 είναι υπέροχος AE101 είναι υπέροχος AE101 είναι υπέροχος
Colored Potholes!!
Colored Potholes: An Excuse to Keep Doing it Wrong the First Time
Italy-based students Domenico Diego and Cristina Corradini think potholes need to be more visible, and your car's suspension probably agrees. Their "Street Safe Initiative" is a program that wants to take the transportation network / organism comparison to another level by "comparing the road surface to the human skin".
When someone gets a scrape, you see red underneath; Diego and Corradini think the same principle can be applied to roads.
"[The concept] comprises a brightly-coloured layer of asphalt a few inches beneath the surface of the road, which becomes visible when the road surface breaks up, making potholes easier to see and avoid."
The Street Safe Initiative will be tested later this year in Italy. If it proves cost effective and feasible, the program may be popping up in other European countries.
That is, unless Mike Conway has anything to say about it. As Managing Director of FM Conway (a highway-fixin'-and-buildin' company), he doesn't think it's realistic:
"It's a novel but it's not the right solution for the UK right now. To make layers of tarmac stick together we use a bituminous coating that acts as a glue and you'd have to go right back to the manufacturing stage and work out how to make it bright yellow. We should be looking at how to reduce costs by doing the job right in the first place, rather than creating expensive solutions that only have an effect once the pothole is already there."
Sure, doing things right the first time may be "cheaper". And "smarter". But where's the fun in that?
Πηγή: scoop.blogspot.com
Φανταστείτε τώρα, να γίνει αυτό στην Ελλάδα
JDMteam
Παλιά 08-03-10, 20:36
Edessaios Offline:
Δύναμη Σεβασμού: 597
Θα αλλάξουν χρώμα όλοι οι δρόμοι.............
My garage
COROLLA EE101 SW
COROLLA ZZE122 1.8
HONDA VFR 800Vtec ABS '05
Παλιά 08-03-10, 22:03
Το avatar του χρήστη Ζήσης
Ζήσης Offline:
Δύναμη Σεβασμού: 344
Αν εδώ στην Ελλάδα κάναμε κάτι τέτοιο τότε σε κάθε μέτρο θα είχε αυτό το χρωμα γιατί υπάρχουν αρκετές λακούβες δυστυχώς!
Αλλά το κράτος φροντήζει για την τσέπη του κ φυσικά κ τους μηχανικούς!!!
http://www.auto24.gr
Παλιά 09-03-10, 02:11
Το avatar του χρήστη Janakas
Janakas Offline:
Επειδη ειμαστε ακομα πιο μπροστα, θα προτεινα να αγορασουμε ολοι απο κανα δυο κιλα ασφαλτο ετοιμη και να κλεινουμε απο μια λακουβα τη μερα!!!!
Χαχχαχαχαχ!!!
Μονο ετσι θα γινει καλυτερη η κατασταση!!!
Koni, bilstein, sachs, kw, d2 kai TEIN επρεπε να εχουν ανοιξει ηδη εργοστασια στην Ελλαδα!
Παλιά 09-03-10, 02:16
giorgisrog Offline:
Μοντέλο: Ε12 1.4 2005 5d
Δύναμη Σεβασμού: 243
Αρχική Δημοσίευση από janakasgr Εμφάνιση μηνυμάτων
Χαχχαχαχαχ!!!
σωστος!!! ενα τσουβαλακι ασφαλτο ο καθε ενας!! οχι οτι θα φτασει βεβαια.....(απο το σπιτι μου στη δουλεια θελει ενα τριαξονικο!!!).....αλλα αν περιμενουμε απο τους φορεις......χαθηκαμε!!!!
...corollaclub ΚΡΗΤΗ...
Page generated in 0,17490911 seconds (78,40% PHP - 21,60% MySQL) with 30 queries
Όλες οι ώρες είναι GMT +3. Η ώρα τώρα είναι 14:20.
