Σασμαν (βαση δεδομενων)
Παλιά 11-05-08, 08:45
TOLIS EE80 Offline:
Μοντέλο: COROLLA EE80
Δύναμη Σεβασμού: 451
Οποιος θελει ας το μεταφρασει
add to the information about corolla gearboxes.
C50: AE82, AE92 (All), AE101 w/ 4A-FE) MR2 Mk1a
Gear Ratios:
1st: 3.545
2nd: 1.904
3rd: 1.310
4th: 0.969
5th: 0.815
Reverse: 3.250
final drive: 3.722
C52 1986 on?: ae82 4age, ae92/3 4age, ae102 w/ 7A-FE, ae101 Silvertop 20v (1st generation), MR2 Mk1b
gear ratios:
1st: 3.166
2nd: 1.904
3rd: 1.310
4th: 0.969
5th: 0.815
Final: 4.058
C56: AE101 Silvertop 20v ((2nd generation) & AE111 Blacktop 20v)
gear ratios:
1st: 3.166
2nd: 1.904
3rd: 1.392
4th: 1.031
5th: .815
final drive: 4.312
C59: AE102 w/ 7A-FE?, AE112R (including Sportivo Turbo)
gear ratios:
1st: 3.166
2nd: 1.904
3rd: 1.310
4th: 0.969
5th: 0.815
C150: ZZE122R
gear ratios:
1st: 3.545
2nd: 1.904
3rd: 1.310
4th: 0.969
5th: 0.815
Reverse: 3.250
C151
gear ratios:
1st: 3.545
2nd: 1.904
3rd: 1.233
4th: 0.885
5th: 0.725
Reverse: 3.250
E58: ae101 4AGZE
gear ratios:
1st: 3.214
2nd: 2.045
3rd: 1.333
4th: 0.972
5th: 0.820
Final: 3.944
C60 6 speed: 99 Celica, ZE123R (Sportivo)
gear ratios:
1st: 3.166
2nd: 2.050
3rd: 1.481
4th: 1.166
5th: 0.916
6th: 0.725
reverse: 3.250
final drive ratio 4.529:1
Similar to other six-speed manuals, a pull-type collar system is in place to prevent drivers from accidentally engaging reverse gear.
C64 6 speed: Lotus Exige
gear ratios:
1st: 3.116:1
2nd: 2.050:1
3rd: 1.481:1
4th: 1.166:1
5th: 0.916:1
6th: 0.815:1
Reverse: 3.250:1
Final drive: 4.529:1
C65M: ZZE31 MR2 Spyder sequential transmission
gear ratios:
1st: 3.166
2nd: 1.904
3rd: 1.392
4th: 1.031
5th: 0.815
6th: 0.725
C160 six speed ratios: AE111 20v Blacktop
gear ratios:
1st: 3.166
2nd: 2.050
3rd: 1.481
4th 1.166
5th: 0.916
6th: 0.725
Reverse: 3.250
Final Drive: 4.529
exploded diagrams:
c52 and e58 comparison:
http://www.toymods.net/forums/showthread.php?t=34995
LSD's can be identified by the VIN, if it ends with and even number or A than it is open diff, if it ends with an odd number or C then it is LSD.LSD shafts are cannot be used with the NON LSD box and vise versa. e58 LSD drive shafts measurements:
http://www.toymods.net/forums/showth...gze+driveshaft
also use these vintags to order parts
http://www.rollamods.com/tech/vintags.jpg
those using the ae101 E58 require the ae92 GTZ or ae95 4wd corolla speedo sensor (right) as the ae101 is a electronic unit (left).
Βαση δεδομενων αυτοκινητων Fanis Γνωσιακή Βάση Δεδομένων 1 20-02-24 09:33
ΒΑΣΗ ΚΕΡΑΙΑΣ Garazakias TOYOTA AURIS 49 22-01-13 15:55
Γνωσιακη Βαση wastegate OFF TOPIC 9 20-02-08 11:57
Page generated in 0,40332890 seconds (87,91% PHP - 12,09% MySQL) with 66 queries
Όλες οι ώρες είναι GMT +3. Η ώρα τώρα είναι 02:25.
