  #41
Παλιά 10-02-10, 17:28
Δύναμη Σεβασμού: 425
Δεν εχω δει ακομα λαστιχο να λιωνει στην επιφανεια απο χειροφρενο!
Εκτος και αν λεμε για πισωκινητο!!!!
ελα να δεις τα δικα μου τοτε...
αν κανεις το χειροφρενο κομπολοι γινεται και παραγινεται!!!
Παλιά 10-02-10, 17:36
Το avatar του χρήστη Ζήσης
Ζήσης Offline:
Δύναμη Σεβασμού: 343
Ρε μπαγάσα κάνεις τόσα πολλά χειρόφρενα?
http://www.auto24.gr
Παλιά 12-02-10, 18:21
tsport192 Offline:
Δύναμη Σεβασμού: 408
Παραθέτω πιο κάτω την επικοινωνία που είχα μέχρι στιγμής με την ΤΤΕ για το θέμα.
Αρχική Δημοσίευση από Tsport192 Εμφάνιση μηνυμάτων
Dear Sir,
I am an owner of a Toyota Corolla E12 facelift 2006, hatchback. I have installed to an authorised dealer your TTE lowering springs (PZ439-E0720-00). I have kept stock shocks absorbers.
After installing the lowering springs went through the normal alignment procedure, only for the front axles since there is nothing that can be done to the rear axle.
I have done 30000km with this set of tyres since then, and I have noticed abnormal tyre wear to the outer of the tyre on both rear tyres. Both tyres have the same ubnormal wear at the same extend. There is nothing wrong though, with front tyres wear.
This is an alarming issue for me. It is not a good thing to have this kind of tyre wear. Are you aware of such issues from other customers? Is there a proven solution to this problem? It seems that Toyota dealers in Greece are not able to provide an official answer on how this problem could be solved.
Thank you in advance for your assistance,
Sincerely yours,
*Tsport192*
Η απάντησή τους...
Αρχική Δημοσίευση από TΤΕ απάντηση Εμφάνιση μηνυμάτων
Dear Mr. το όνομά μου,
Many thanks for your e-mail.
We are not aware about such a problem because it normally doesn't happen under the condition that alignment is done. I wonder that your dealer haven't done it at rear axle as well.
The values are identical to the standard Toyota procedure to be available in the service & repair manuals.
Please contact your dealer to check the status of the rear axle.
Best regards
Το όνομά του
Manager Business Development & Distribution
Sales & Sports Conversions
Tel. +49 2234 1823 620 | Fax. +49 2234 1823 387 | Mobile +49 152 22960 348
Email: friedel.beyer@toyota-motorsport.com
Web : www.toyota-motorsport.com | www.tte.de | www.toyota-motorsport.com
Toyota Motorsport GmbH | Toyota-Allee 7 | D-50858 Koeln (Germany)
Και απαντώ ευθύς αμέσως....
Hello Mr. το όνομά του,
First of all I would like to thank you for your prompt response.
I am sure you are aware that Corolla E12 has semi-rigid shaft as rear axle. I was under the impression that it is not possible to do any kind of alignment in such case. In the last authorised dealer that I serviced my car, that was confirmed.
If you are saying otherwise, perhaps it is time for me to change authorised dealer...
Please confirm.
Thank you for your assistance,
Regards,
Το όνομά μου
Δεν έχουν απαντήσει ακόμα, η τελευταία επικοινωνία ήταν χθες....
"Φάγωμα" χρώματος στις κόγχες μετά τις πίσω πόρτες CTS03 TOYOTA COROLLA E 12 7 12-05-11 12:58
Σταύρωμα ελαστικών??? Garazakias TOYOTA AURIS 14 15-01-10 10:37
Πίεση ελαστικών basillis TOYOTA AURIS 21 02-03-09 15:45
Πίεση Ελαστικών nicknas SUPPORT 59 12-09-05 22:10
Page generated in 0,12774396 seconds (78,44% PHP - 21,56% MySQL) with 27 queries
Όλες οι ώρες είναι GMT +3. Η ώρα τώρα είναι 18:55.
