Παλιά 11-02-08, 01:19
Δύναμη Σεβασμού: 594
αφου ιδια πανε σχεδον πως γινεται?
Παλιά 11-02-08, 01:22
Το avatar του χρήστη johnboy
johnboy Offline:
Δύναμη Σεβασμού: 283
Αρχική Δημοσίευση από trd.si Εμφάνιση μηνυμάτων
αν μπορουσα να φερω ενα καλο μοτερ θα εφερνα το 7afte 1.8t με 170 ιπ κ πολυ ροπη γιατι μπαινει κουτι στο κορολλακι μου κ δν χρειαζονται μετατροπες.αλλα αντε βρες το
υπηρξε μαμα 7afte?
7A
The largest A-series engine was the 1.8 L (1762 cc) 7A-FE. Produced from 1993 to 1998, it was a 4-valve DOHC narrow-valve-angle economy engine. Cylinder bore was 81 mm (3.19 in) and stroke was 85.5 mm (3.37 in).
An early Canadian version produced 115 hp (86 kW) at 5600 rpm and 110 ft·lbf (149 N·m) at 2800 rpm. The most common version is rated at 115 hp (86 kW) at 5600 rpm and 115 ft·lbf (155 N·m) at 2800 rpm engine.
In the United States, the 7A-FE's most common application was in the 1993–1997 Toyota Corolla (7th generation). The engine was also used in some 1994–1999 Toyota Celicas (6th generation) at the base ST trim level, as well as the Toyota Corolla's clone, the Geo Prizm.
Since the 7A shares the same layout as the 4A it is possible to create a 7A-G(Z)E out of a 7A-FE bottom and a 4A-G(Z)E head and pistons. Since the 7A is a very common engine the upgrade from 4A-G(Z)E to 7A-G(Z)E should be relatively cheap. This is a popular upgrade amongst drifters (mostly AE86 drivers) who are always in need of more torque.
The Indonesian and Russian version of 7A-FE has strongest output, 120 hp (89 kW) at 6000 rpm and 16 kgf·m (157 N·m) at 4400 rpm, with 9.5 compression ratio. It appears in the 8th generation Corolla (AE112).
It is a noninterference type engine.
στη wiki δεν το αναφερει...
Παλιά 11-02-08, 01:55
DaveMustaine13 Offline:
Δύναμη Σεβασμού: 336
Roy-D : 0-100 6,6 δευτερολεπτα το παλιο 7,4 το καινουργιο !
Παλιά 11-02-08, 07:54
Το avatar του χρήστη Ayrton
Ayrton Offline:
Μοντέλο: Avensis 2009 1.8 CVT
Ηλικία: 48 male
Δύναμη Σεβασμού: 541
ΕΠΙΔΟΣΕΙΣ
Μέγιστη ταχύτητα (Μηχανικό) (km/h) 235
Επιτάχυνση 0 -100Km/h (Μηχανικό) 6,6
Αυτά είναι τα νούμερα για το καινούριο τάπερ. Κάτι κάνεις λάθος μάλλον!
"Racing is in my Blood......
............... its my LIFE"
Corolla Club
Administration Group
Διοικητικό Μέλος
Παλιά 11-02-08, 10:21
Το avatar του χρήστη john2121
john2121 Offline:
Μοντέλο: G6 1.4 Φ.Π.Ε
Δύναμη Σεβασμού: 239
john2121 είναι σε έναν διακεκριμένο δρόμο
Δεν νομίζω γιατί το καινούργιο έχει πιο κοντό σασμάν άρα πιο γρήγορη επιτάχυνση άρα μάλλον είναι ακόμα λίγο πιο μπροστά.
Παλιά 11-02-08, 10:27
Ayrton Offline:
Ηλικία: 48 male
......και συμπληρώνω.... Εχει και πολύ καλύτερη χαρτογράφηση απο το προηγούμενο..... το οποίο του δίνει ροπή απο πολύ πιο χαμηλά σε σχέση με το παλιό. Ομως αυτό δημιούργησε ένα μοτέρ πολύ πιο γραμμικό απο το προηγούμενο, και για αυτό δεν έχει την αγριάδα του παλιού! Είναι όμως πιο καλό.....
Corolla Club
Διοικητικό Μέλος
Παλιά 11-02-08, 10:28
Το avatar του χρήστη akis308
akis308 Offline:
Μοντέλο: ΑΕ 92
Δύναμη Σεβασμού: 477
Αρχική Δημοσίευση από johnboy Εμφάνιση μηνυμάτων
υπηρξε μαμα 7afte?
Όχι δεν υπάρχει, υβρίδια είναι όλα αυτά, κοινώς μοντίφες....
Παλιά 11-02-08, 13:22
Το καινουργιο το ταπερ ειναι και 120 κιλα πιο βαρυ αν δεν κανω παλι λαθος..επιμενω παντως οτι το καινουργιο το ταπερ ειναι πιο αργο απο το προηγουμενο
Παλιά 11-02-08, 13:32
Ayrton Offline:
Ηλικία: 48 male
Εγώ σου είπα τα νούμερα...... απο εκεί και πέρα.... στον δρόμο.... δεν έχω πετύχει καινούργιο ακόμα για να ξέρω τι κάνει δίπλα μου (και πριν λαλήσουνε "καλοθελητές".... για να κρίνω απο την διαφορά που θα μου κάνει!!!).
Corolla Club
Διοικητικό Μέλος
Παλιά 11-02-08, 22:46
Το avatar του χρήστη 2579
2579 Offline:
Μοντέλο: AUDI A4 20vt
Δύναμη Σεβασμού: 322
παιδια στο drive του μαιου 2007 δινει 7 δευτ στο καινουριο με ελαφρομενο βολαν και καλυτερη χαρτογραφηση φυσικα και 100 κιλα βαρυτερο το παλιο αλλοι λεν 6,8 και αλλοι 7,2 τωρα πιο ειναι σωστο τι να πω.
η απαντιση
Corolla TS Vs Type-r Θωμας.Κ TOYOTA COROLLA T-SPORT 283 19-03-15 00:31
NikiforosGT corolla turbo EE111 Greedy RS type NikiforosGT Videos 53 02-12-10 18:44
t-sport / type r elpis OFF TOPIC 14 01-10-06 03:01
Corolla E12 1.6 110ps VS Civic 1.6 115ps Elefsinaaaara_CorollaPowe TOYOTA COROLLA E 12 13 11-01-06 20:12
Κοντρα Corolla G6 1.6 Me Ηονda Civic Vti dimitris ΓΕΝΙΚΑ ΘΕΜΑΤΑ 67 07-07-05 11:04
Page generated in 0,22773695 seconds (81,28% PHP - 18,72% MySQL) with 42 queries
Όλες οι ώρες είναι GMT +3. Η ώρα τώρα είναι 09:24.
