Βρηκα αυτα τα coilover. Ειναι κατοπιν παραγγελιας και ειναι για ΑΕ92/101/111 αλλα με καποια μετατροπη κανουν και για μενα στο ποσο των 900ευρω με τα μεταφορικα. Συγκεκριμενα:
Fully adjustable ISC coilovers for toyota corolla ae92/101/111
**Will not fit superstrut type suspension**
30 way adjustable shock rate
Adjustable platform height
Adjustable strut length
Front Camber plates
Adjustable rear camber
8kg/mm front springs
6kg/mm rear springs
52mm piston/cylinder design
20mm piston shaft
Steel Hub adapters powder coated
Come with C spanners and brake line adapter kit.
Shocks can be taken out of the case and be replaced/rebuilt. 1 year manufactures warranty.
Different spring rates can be chosen.
These can be made to fit ae82s. There will be an extra cost involved of $80 for front and rear camber plates which I have to get made as the bolt pattern on the ae82 is different (Laser cut aluminium tops for front and laser cut mild steel for rear). And $20 to mill the the rear hub adapter slightly to fit the ae82 rear hub. You will also get to keep the ae92/101/111 top hats, if you decide to change car or sell them.
