Αρχική Δημοσίευση από mechanicaf";p="6293
καλα ρε παιδια να ρωτησω και εγω κατι;Ποιος εχει δει 245 στο κοντερ του γιατι εγω με 5η στις 8000 (6αρι σασμαν) ισα που περασε τα220 σε ευθεια παντα.Αν ειναι σε κατηφορα το ξεχναμε σαν να μην το ειπαμε αλλα σε ευθεια;τι διασταση φορατε για να κλεβει τοσο πολυ;
Επειδη φορας το 6αρι.Εγω με το 5αρι μπορουσα να βγαλω πολλα χιλ,αλλα με το 6αρι που εχω τωρα επανω η τελικη μου,εχει μειωθει κατα πολυ.
Αυτο(σχετικα με το σασμαν)αναφερεται και σε αλλα club:
http://www.automotiveforums.com/t145473.htmlin a way your right and another your wrong... what can I say... you guys have been deprived of the 4age/4agze series leaving you stumped on facts!!!
GZE
there is 3gen's of gze engine the last one was in the late 2years of the AE92(89-91) along with the AE101(91-95) (didnt go into AE111 since 20v making near the same power and N/A been cheaper to insure)
4age
they go back to the days of "bluetop" and "redtop" I think you guys recived some powerdowed versions, then the 20valve Silvertop 91-95
in the years of 93-95 they recived some xtra tunring and better porting making them faster than the 91 and 92's, then on modle change to the AE111 (95-99) same here in 97-99 they recived some xtras along with some safty xtras.
6speed Vs 5speed
The 6speed is best in track use since the closer ratios are good for corners but on a 1/4 mile strip or top speed the 5speed is much quicker, the 6speed tops out at 205kmph while the 5speed pushes onto 237kmph
if I was looking at buying anything again it would have to be a 1993 up AE101 or AE111 and if you think the gze would whip a silvertop 20v semi true at slow speeds but higher up 20v will pull onit, and in my case a stock gze dosnt stand to much of a chance aganst my 20v, and car wise the AE101 has a nicer interior over the AE111
learn people learn!! we have thise cars all over the place here!
you deprived Barstards!
Αν διαβασεις και τα προηγουμενα που εχω αναφερει τις διαφορες 5αρι με 6αρι,θα δεις οτι η τελικη αυτη ειναι πραγματικη.Με το 5αρι π.χ. που ειχα 2α-120,3η-155,4η-185 και η 5η εφευγε κατα πολυ απο τα 220...(μεχρι εκει ειναι το κοντερ μου)
Σχετικα με το αν κλεβει,με 195/50/15 μεχρι τα 180 δεν εκλεβε καθολου.Αυτο το ειχα τσεκαρει πριν βαλω τον αντικοφτη και πραγματικα τα κοψιματα μου τα εκανε οταν η βελονα εγραφε 180...
